DJS4000
- Nov 2, 2009
@DJS4000: #2 is an interesting proposition. In the Dell Venue Pro configuration, the base doubles the battery life. So I'd imagine it might only be 6 hours as a "Clipboard". But like the DVP, you would simply hook the screen back to the base to get the other 6 hours out of it. We all know you're not getting up to 12 hours if the Nvidia GPU is running. What could be more interesting is if you can tune how it uses battery charge. On the DVP I think it pulled from both equally, but I can't remember exactly. So you could use the device for part of the day as a laptop, take off the bottom half and throw that on the charger while you use the tablet. Then once the tablet is depleted you can just plug the base back in and use it as a laptop again for more time. So if you are using it heavily there are scenarios where you can get more than a single charge out of it by charging part of the device back up while you're using the other part. Also, in a situation where let's say you have multiple of them in the same area (We have done this in a work environment), you can steal someone else's base unit which is already charged and use that for extra battery.
well, in some of the cutaways the whole base appeared to be mostly batteries next to the GPU, so i would expect a massive boost in runtime with it attached.
also, the part about swapping bases for continuous workflow is a good idea. the new generation ThinkPad uses a kind of similar system, where the laptop has a detachable battery and an internal small capacity "bridge" - battery. this allows you to change main batteries without powering down, which is neat. it also charges the internal battery first.
i'd imagine it to be similar with the surface book.
