XBarbarian
- Dec 29, 2006
Hi
just received my 1080 GTX Ti (w00t)!
Dell U2713HM Display. was connected with a DVI to my old 680gtx. so I used the supplied DP to DVI adapter.. but the machine is NOT seeing anything higher than 1080p as a resolution? is that an issue going from DP to DVI?
also, I bought this card directly from Nvidia store. is ther a free type app for monitoring temps etc of the card or are those proprietary with EVGA etc cards?
thank you
thank you
