D
Deleted member 143938
Guest
For some reason my SuperPI has the same score of 32 seconds at 1M at stock speeds of 2.4 and 200Mhz for RAM and at my OC speeds of 2.6 and 300 RAM, I thought it should shave off at least 2 seconds
Ah. And no actually, I had to tighten them to get this 300. stock is 200 2-2-2-8, now it's 3-3-3-8Sta!nless said:Did you loosen your timings when you got to 2.6? Timings makes a little bit of a difference, not much though. Also you might even have to go up to 2.65, 2.7 to see even one second dropped off your time.
Tylerdurdened said:Ah. And no actually, I had to tighten them to get this 300. stock is 200 2-2-2-8, now it's 3-3-3-8
