CombatChrisNC
- Apr 3, 2013
So this is the plan... getting a used supermicro server, 12, 24, or 36 bay, and then using it for archival storage, media streaming, and potentially host a few VM's.
The host will be running Server 2012.
The question I've got is about the SAS connectivity that the backplanes provide.
This is the server I'm strongly considering. http://www.ebay.com/itm/Supermicro-...016?pt=LH_DefaultDomain_0&hash=item35e9b05888
The backplanes that come with it, according to that chassis number from Supermicro, are these: BPN-SAS2-826EL1 and BPN-SAS2-846EL1
Which according to these... http://www.supermicro.com/manuals/other/bpn-sas2-846el.pdf - page 17
http://www.supermicro.com/manuals/other/BPN-SAS2-826EL_1.0.pdf - page 15
.... are each capable of handling all the disks plugged into them via a single SAS cable. That's OK, I'll get myself an LSI 9211-8i and call it a day if that is indeed how it works.
But this is the real question... I want to use Storage Spaces for the needs listed above while running the OS on RAID1 from the Mobo's SATA ports. So how can I get the SATA ports connected to the disks if they're sitting in their trays and connecting right up to the backplane? What's even the point of having those mobo SATA ports if you can't get the disks housed in a way where you can connect them! I'm considering even getting a pair of ~128GB SSD's and ZIP TYING them somewhere in the case to support my OS install.
Thoughts? Anyone with hands on experience with these chassis?
