Hi Folks,
I recently made a new NAS server based on a TYAN s7002 and 2 Xeons E5504 processor. The PSU I use is a Supermicro PWS-0047.
The motherboard have 2 8 Pins connector for the CPU. As I have only one, I use the 4 PIN one with a converter (here are pics of it). Everything work fine, I made some load tests and no problem at all.
BUT I recently use hardware monitor and get a very strange results on the +-12V... you can see it is around 7V. It is definitively not normal, but I wonder you opinions about it.
Is it a problem with the software? I do not get any problem of instability, so I do not know what to do... Any helps or explanation are welcome
cheers,
Sergio
http://hardforum.com/showpost.php?p=1036548024&postcount=1022
cheers,
Sergio
