I don't know about you guys, but in this era of double-slot video cards, those CMOS reset jumpers are getting impossible to reach without removing components.
I was looking into fashioning a switch when it occurred to me. . . most CMOS Clear jumpers are 3-pin. So are fan connectors.
Sure enough. . . a 3-pin fan power cable extension fits perfectly. I got mine here at Jab-Tech. Just pop it on the jumper, make note of which wires are the "no clear" ones, and put the jumper on the end of the extension cable. Works like a charm.
I've now done this on three systems (been building some 8800-based systems and they all needed this). I don't think I'll be mounting any motherboards in the near future without adding this little guy on there!
