1) What will you be doing with this PC?
Lots of video (would like to be able to play 720p video), light gaming (WoW in 1680x1050)
2) What's your budget?
$300-$350 w/tax+shipping
3) Where do you live?
California
4) What exact parts do you need for that budget?
Everything, I do have some spare parts from my old computer, however they are outdated
5) If reusing any parts, what parts will you be reusing?
3 IDE Drives; DVD, DVD-R/RW, 200 GB HDD
Also have an EVGA GeForce 7900GS KO, but could probably do with an upgrade even w/my low budget
6) Will you be overclocking?
No
Acer AL2016W (20" Widescreen LCD, No DVI)
1-2 Weeks (ASAP)
9) What features do you need in a motherboard?.
Just the basics
10) Do you already have a legit and reusable/transferable OS key/license?
Yes, XP/Vista/Win7
My previous desktop stopped working last week, and is too old to invest any more money into, so I'm looking for a cheap temporary fix so-to-speak here. This would be my first attempt at putting my own PC together. I've replaced parts before and took my previous computer apart and put it back together last week trying to revive it, so I've got a little bit of experience with this stuff. There are still some things I could use some advice on; mainly Power Supplies and Graphics Cards. Like I stated above, I do have the card from my last computer, however I know extremely little about GPUs and which (if any) of the cheap-o ones out there would be better than what I already have. With power supplies I understand that the total wattage doesn't necesarrily mean much, but everything else I've read doesn't make a whole lot of sense to me as I know nothing regarding electronics.
Here's a list of possible components, I've put together quite a few over the past few days, this being the most recent..
CPU/Case: AMD Athlon 64 X2 7750 Kuma 2.7GHz & Antec Three Hundred Black Steel ATX Mid Tower Computer Case
MOBO: PC CHIPS A15G (V1.0) AM2+/AM2 NVIDIA GeForce 6100 Micro ATX AMD Motherboard
RAM: Kingston HyperX 2GB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model KHX6400D2/2G - Retail
PSU: Antec earthwatts EA430 430W Continuous Power ATX12V v2.0 80 PLUS Certified Active PFC Power Supply
HDD: Western Digital Caviar SE WD3200AAJS 320GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive - OEM
GPU: ASUS EN8400GS SILENT/HTP/512M GeForce 8400 GS 512MB 64-bit GDDR2 PCI Express x16 HDCP Ready Video Card
TOTAL: $344.12 (incl. $26.23 Tax & Free Shipping)
I'd love some advice here as I'm just looking for the cheapest compilation of parts possible to achieve my needs.
California
No
1-2 Weeks (ASAP)
Just the basics
Yes, XP/Vista/Win7
