Friend of a friend needs a basic compy, but I'm not sure what to do on this budget.
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
TF2, L4D2, and general use.
650 max.
3) Where do you live?
Oregon.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Entire box. No mouse, keyboard, or monitor.
None.
6) Will you be overclocking?
No.
20"
This month.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support?
None.
10) Do you already have a legit and reusable/transferable OS key/license?
Yes.
I figure ATI and AMD would be the way to go, ram can be slow, doesn't need a lot of storage. Cheap case is fine.
Thanks
650 max.
Oregon.
None.
No.
20"
This month.
None.
Yes.
Thanks
