I am looking to upgrade my CPU, Mobo and Ram. I am a competition gamer so eye candy is not as important as performance aka FPS. Right now my specs are:
Athlon 64 3000+ Single Core (Venice) (OC'd to 2.25ghz)
G. Skill DDR 400
Biostar Mobo (decent overclocker)
7900gs (OC'd 540/800 not trying to push the core to much atm)
I pull around 125fps constant in most maps with others dipping into the 80's and 90's in some certain areas but nothing lower and only for short periods of time. My goal is to have 250fps (legal competition amount) constant eventually when I upgrade my Vid Card using EVGA's 90 day step-up as the 7900gs was just something to hold me over until I made sure that I really wanted to upgrade. I don't expect to have 250fps constant on all maps with what I'm posting below but coupled with a 8800gts there should be no problems. The game I play is CoD2 Dx7 Normal graphics and a few things tweak in my config for performance. I'm looking to upgrade and get my best bang for the buck. Here's what I've been looking at:
E4300 - $115
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115013
G. Skill 2x1mb (DDR 800) - $115
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231065
Tuniq Tower 120 - $55-65
http://www.newegg.com/Product/Product.aspx?Item=N82E16835154001
Motherboard?
I've looked at:
GIGABYTE GA-965P-DS3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128042
MSI P6N SLI Platinum (but I don't believe that I will ever SLI... who knows though)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130081
EVGA 650i or 680i (again SLI, probably won't need it but it's nice to have the option)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188017
I've heard people mention ASUS and DFI. What I'm looking for is something that will overclock a E4300 well enough, nothing extreme, and also have rock solid stability. I currently only plan on using one card but SLI is always an option in the future as games continue to demand more and more from our computers. I've noticed that the GIGABYTE supports the 1333 FSB which will be useful when processors start coming out with those specs in the future (i.e. - Q3 Intel quad offerings).
The only reason I'm considering a E4300 to a 6320/6420 right now is because of Q3 Intel and the quad processors/6850/etc. I've also looked at the C2D 6420, but I don't really need the extra 2mb of cache and with the prices dropping considerably in Q3 for Intel if I really need it then that's always an option.
I've tried to include as much starting information as I can and I really do appreciate any help. My budget is preferably $500 or less...
Thanks,
Steve
G. Skill DDR 400
E4300 - $115
Motherboard?
I've looked at:
Thanks,
Steve
