Suggestions on upgrading old P4
brennok
I have an old system which has treated me well but I figure it is time to upgrade since the NB fan has died again. I am currently running a P4 2.4 on the Abit IC7-G with 1gig of ram. I am looking to spend around $600 or so and the system will primarily be for surfing and mp3s. I already have a dedicated gaming rig.
I need a CPU preferably Intel, Mobo, memory and powersupply. I will be using my Audigy 2 ZS, Nvidia 7900 GT from gaming rig which will be getting a DX 10 card, hard drives, speakers and monitor from the current pc.I already have a case on order, the CM 690 which ZZF had for 39.99 AR.
Intel Core 2 Duo E4400 CPU - $123
Abit IP35-E Intel P35 Motherboard - $89
G.SKILL F2-6400CL5D-2GBNQ 2 x 1GB DDR2 800 RAM - $70
Corsair VX450 450W PSU - $76
Total: $358 Plus tax and shipping.
For just web browsing and MP3s, the above is all that you really need. But just in case, I've left you some options:
If you need more than 4 SATA ports, then go with the GA-P35-DS3R since it has 8 SATA ports:
GIGABYTE GA-P35-DS3R Intel P35 Motherboard - $130
If you want 4GB of RAM, I recommend this set:
G.SKILL F2-6400CL5D-4GBPQ 2 x 2GB DDR2 800 RAM - $175
If you want a bit more power or a PSU that has modular cables for easy cable management, then I recommend the Corsair 520HX:
Corsair HX520 520W PSU - $100
If you want to overclock, then I recommend these HSF:
Scythe SCNJ-1100P Ninja HSF - $36
Tuniq Tower 120 HSF - $45
If you hadn't already ordered a case, I would've recommended going with a cheap Dell sans monitor and replace parts as needed.
What features do you need on the mobo? RAID? Firewire? Legacy ports?
Danny's build is more than sufficient for your needs. If you want to fill out that budget more...
$189 - Intel Core 2 Duo E6750 Conroe 2.66GHz
$110 - Crucial Ballistix 2GB (2x1GB) DDR2-800 BL2KIT12864AA804 ($47 MIR)
$91 - abit IP35-E LGA 775 Intel P35 ($20 MIR)
$70 - Enhance ENP-5150GH 500W 80+ Efficiency
$460 + tax and shipping - $67 MIRs
If you want, you can actually bump that to a Q6600 for about $100 more:
$276 - Intel Core 2 Quad Q6600 G0 2.40GHz 8MB L2 LGA775 BX80562Q6600 SLACR
If you have more than 2 PATA devices, you could get a PCI IDE Controller card.
EDIT: Sorry, forgot this was a secondary machine... for surfing and playing MP3's, all you need to spend is $300 ( X2 BE-2350, TForce 560+, 2GB DDR2-800, XClio Goodpower 500W)
Yeah the more Sata and Ide ports the better. Most of my old hard drives and even the CDRW and DVD drive are IDE. I may just upgrade the DVD and CD drive since they are beige though. I am running a fios 20meg down 5 meg up so I definitely want a board that can handle that with ease. It is probably just due to age but it seems this system never could keep up with the speeds even just on speed tests.
How loud are those HSFs? I really would like to keep the system fairly quiet since it is in my bedroom and I tend to leave my pc on 24/7. It doesn't have to be perfectly quiet but I don't need a jet engine lol.
Thanks I will look at those components. I had debated on possibly going with the Bad Axe 2 since it is what I am using in my gaming rig and I haven't had any problems though it is probably overkill. Worst case I may bump my cpu up on the gaming rig and use that processor for this rig. In the gaming rig I have a C2D E6600 Conroe 2.4ghz LGA 775. I will probably go 4gb of ram only since I may dual boot since I believe I can get both xp and vista really cheap through the local university.
The Scythe Ninja and Tuniq Tower 120 are two of the most quietest HSFs out there. You won't have to worry too much noise with them.
Most mobos, well enthusiast boards anyway, these days come with gigabit ethernet ports, so file transfers on your LAN won't take too long. The mobos that Enginurd and I linked to as a gigabit port.
As for IDE ports, a lot of mobos have only one IDE port these days, like the one I recommended. So I recommend that you get a PCI to IDE add-on card for around $14 to $20 or so. With a PCI to IDE add-on card, you can add an extra 4 IDE devices. Here's an egg hunt:
http://www.newegg.com/Product/Produ...Subcategory=410&description=&Ntk=&srchInDesc=
If you want an SATA burner, I recommend getting this:
Samsung SH-203B 20X DVD±R SATA DVD Burner - $32
In PC's, a larger fan means less noise and more airflow. ;)
If you're upgrading your gaming rig CPU, the best choice is the Q6600.
