I'm finalizing a build for a friend and want to make sure everything is critiqued perfectly before making the final purchase. The build has to be under or at $1000 out the door. The primary function will be a college PC used for multitasking but it will also be for some moderate gaming (nothing like Crysis).
Case: Antec 900
PSU: Antec earthwatts EA430 430W ATX12V v2.0 Power Supply 100
MoBo: DFI BloodIron P35-T2RL LGA 775 Intel P35 ATX Intel Motherboard
CPU: Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor
CPU Cooler: ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler
RAM: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
HDD: WD3200AAKS
GPU: SAPPHIRE 100225L Radeon HD 3870 512MB 256-bit GDDR4 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
A DVD/CD burner combo and Windows Vista Home Premium 64-bit
EDIT: PSU changed to:
Corsair CMPSU-450VX PSU
CPU Cooler changed to :
Xigmatek HDT-S1283 120mm Rifle HSF with Xigmatek ACK-I7751 Rentention Bracket
Purchase will await new GPU releases so graphics card will not be factored in at this moment.
Case: Antec 900
HDD: WD3200AAKS
