Suggestions Needed for Mini-Itx system
The HD4890 with an i7 965, 6x DDR3 sticks of RAM, and a single HDD/OD will only pull around 300W at stock clocks, according to reviews I've read.
Thats pretty good.
But unfortunately i will have an e5200 with Hd 4890, 4gb Ram and 1tb hhd not i7 sytem yet.
Thats pretty good.
Sorry, I didn't quite finish that post...
Since an E5200 (65W) pulls half the power of an i7 965 (130W), then a 450W Corsair unit will definitely be enough. ;)
Great, but i been having thoughts about crossfirex and i want a psu that would be able to handle 2 4890 if i actually get them later on.
Now i got another question i need 4 fans a silent as possible but with good cooling. I need 2 120mm fans and 2 60mm fans. There are just too many fans to choose from and i have no idea which are quieter and provide a good air flow.
For two HD 4890 CF, I'd recommend at least a quality 750W PSU.
Excellent page/site for quiet fan info and recommendations:
http://www.silentpcreview.com/article63-page2.html
I typically get Yate Loon 120mm fans because they're so cheap. If someone thinks its too loud, I simply volt mod it. /shrug.
Jab-Tech normally have them the cheapest. They can also be found at FrozenCPU, Petra's Tech Shop, and a few other locations for around $4-$6 per fan.
Shipping suck on this places.
Thanks for the info..
I guess it depends where you are, since shipping 3 - 9 120mm fans (D12SL-12) to me is only $6 from jab-tech (regardless if its 3 or 9). So its only $16 for 3 fans, whereas a single Scythe Slipstream is $9 + $3 shipping from newegg. I guess you could try those 120mm cooler master or other brand fans from newegg if they're cheaper.
I want to thank everyone who help me with this build. I know that i didnt quite follow your suggestions but they did help me alot.
The final parts i ended up with are:
RAM-2x2GB Patriot Viper DDR2-800 (PC2-6400)
-2x2GB Kingston HyperX DDR2-1066 (PC2-8500)
MB G33M-DS2R
This items above i got from the same person on the fs section.
HHD 1tb hitachi.
CPU E5200
VC XFX Hd 4890 1gb
Dvdr rom- reuse old one.
HSF Cooler Master Hyper 212+
Corsair - 750W ATX - I got this because i might cross fire later when i go i7.
Generic case I had from my first build 6 years ago. I pulled apart cut some fan holes and side window and painted flat black.
The only things that i think i'm missing are Some case fans and cpu hsf.
What would you guys recommend for a cpu hsf?.
Now i just got to put it together when some parts arrive.
Thanks for everyone's help.
DS2R? Nice board.
Could you please post some HDTune screenshots of that 1TB Hitachi when you get it all set up?
As for the HSF, these are popular choices: Cooler Master Hyper 212+ and Xigmatek Dark Knight.
Post pics of the build! :)
DS2R? Nice board.
Sure will when i get it all together.
Thanks
I just wanted to share the progress with you guys.
Here a link with pictures of the items on hand and the case i will be using before i did i little clean up. I was just waiting for the motherboard which just arrive. So hopefully it should be up and running by tomorrow.
Here is the Link.
http://www.flickr.com/photos/ride2kmax/sets/72157623148317120/
Sorry about the bad pictures. Took them with my cell phone.
I will upload new pictures when i put it together.
DS2R? Nice board.
www.flickr.com/photos/ride2kmax/4251771145/
Here is hd tune screen shots of my drive.
I dont know much about it. The windows index experience gave me 5.9 for disk data transfer.
Is it good according to the picture?
I posted the results a few post back. Just so you know.
Yah, looks ok. Hoped it would be faster, but I guess its not using 500GB-platters. Thanks for the pics! Nice paint job. I actually have one of those cases, lol, but I gave it to one of my cousins.
This case is from my first build 6 years ago. My wife bought it for me so i had to do something to it and not just leave it collecting dust. That why i kind of retouch it.
Now i got a question i'm using the cm 212plus hsf on a e5200 and i'm getting a idle temp of 32c and maximum temp after 24 hours of prime95 52c average was 42c.
Is that about right ?
Hehe, 42°C @ load? nice. If and when you decide to OC, just make sure the load temps don't go over ~60°C (ie. you have a lot of headroom :p).
I started overclocking. Right now the e5200 is running at 3.5 with vcore at 1.29. Ran prime95 for 8hrs highest temperature was 52c. I wil keep it like this for sometime.
Nice OC. As you can probably tell, it should go higher. Though, I agree, leaving it at 3.5Ghz should be fine for quite a while.
Now i want to overclock the video card but i dont know much about it. How to test and tell if is stable after the overclock.
