Suggestions for workstation build
obs
Development
Sub $2k w/ dual monitors
3) Where do you live?
USA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
Motherboard, CPU, RAM, case, PSU, monitors, HDDs, GPU, DVD burner, keyboard, mouse
None
6) Will you be overclocking?
No
~23-24", 1900x1200 or 1900x1080
Next week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
RAID 1 most likely a must. Crossfire/SLI, USB 3.0 & SATA 6Gb/s nice but not necessary.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes
So with some changes at the company I work for I need to get a new machine ordered and built quick. This machine will be used 99% of the time for Visual Studio development and installer creation. Will also need a decent gpu as the product being developed is CAD software. No overclocking will be done. Sub $2k budget with dual monitors. Stability, performance, and being quiet are all needed (in that order).
Some preliminary thoughts:
Motherboard: Asus Sabertooth X58
CPU: Intel Core i7-950
RAM: G.SKILL 3x2GB DDR3 1600
HDD: WD 1TB RE3 x2 in RAID 1
GPU: GTX 460
Case: Antec Sonata w/500w PSU
Not sure about monitors yet.
Make sure that you buy that mobo and CPU from this combo link to save $35:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.523542
Ditch the Sonata w/500W PSU. The Sonata case is not that good of case when it comes to cooling, ease of cable management and assembly, and room. I recommend any of these cases instead:
$50 - Cooler Master Elite 335 RC-335-KKN1-GP ATX Case
$50 - Thermaltake WingRS 201 VJ60001N2Z ATX Case
$60 - NZXT M59 ATX Case
$70 - Lian Li Lancool PC-K56 ATX Case
$70 - Cooler Master RC-590-KKN1-GP ATX Case
$70 - Cooler Master CM690 II Basic ATX Case
$90 - Cooler Master CM690 II Advance ATX Case
$90 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$90 - Lian Li PC-7B Plus II ATX Case
$105 - Fractal Design Define R3 Black ATX Case (Fill in the ++++ with "N C I X" without the spaces)
$105 - Fractal Design Define R3 Titanium ATX Case (Fill in the ++++ with "N C I X" without the spaces)
$105 - Fractal Design Define R3 Silver ATX Case (Fill in the ++++ with "N C I X" without the spaces)
$100 - Lian Li Lancool PC-K7B ATX Case
$110 - Lian Li PC-7FN ATX Case
$120 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$140 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$140 - NZXT Phantom PHAN-001WT Black Full Tower ATX Case
$140 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
$135 - Antec P183 ATX Case
PSU wise, I recommend this PSU:
$90 - Corsair 650TX 650W PSU
RAM wise, for $15 more, you can get an extra 2GB of RAM:
$140 - 2 x G.Skill Ripjaw Series F3-10666CL9S-4GBRL 4GB DDR3 1333 RAM
No there's no difference between triple and dual channel RAM in real world performance. Same goes for DDR3 1333 and DDR3 1600 RAM.
