Suggestions for SLI build
sektor
Finally taking the plunge...a SLI build with 8800 cards (haven't decided which ones yet).
Can't decide if I want dual 22" monitors (RTS games taking advantage of that now), or a nice 24" monitor.
Anyway, I really wanted some feedback for the following components:
-motherboard
-case that is spacious enough to hold everything
-cooling the vid cards
-Power (I do like the corsair 520 unit....open to suggestions)
This will be setup with a C2D 6600 (thermalright CPU cooler) and 4gigs G.Skill memory, DDR2 800. (2) Seagate 320 SATA drives...1 DVD drive.
I am a little concerned about space inside the case. My current build, I have a Thermalright HR-03 vga cooler with a 90mm fan mounted on top of it, cooling my x1900xtx video card. Looking at it last night, I was like "How would I fit another video card in here if I wanted to run SLI?"
Any suggestions?
Trying to plan accordingly with some of the very cool games coming out.
I appreciate it.
Cheers.
Do you have a budget?
If I recall correctly SLI won't work on dual monitor setups, though I might be wrong xD
24" monitor, because you can only use one monitor in SLI mode.
The Corsair 520 really isn't enough for a setup with SLI'd 8800's. At all. The PC Power and Cooling Silencer 750 Quad ($170 direct from PC P&C) or a similarly high rated Etasis, Silverstone Olympia, Thermaltake Toughpower, or Seasonic unit would be a far better choice.
Motherboard, the best out there is the EVGA 122-CK-NF68-A1 (or the T1 if you don't mind a slightly smaller bundle and 3 year rather than lifetime warranty with the A1). The ASUS Striker Extreme has issues the EVGA boards do not, and the added cost just isn't worth it for most people.
For the case, it depends on budget. A P180/P180B/P182 would fit a SLI rig just fine, but something like a Silverstone TJ-09 would be ideal, but would cost more than 3x as much. Also really depends on your personal opinion of various cases.
So far as cooling, the cards are sufficiently cooled with the stock coolers and a couple of $5 single slot blowers mounted beneath them to pull air out of the case faster. You could go to water cooling, but this would increase cost a great deal as waterblocks and RAMsinks for these cards can be $100+ each, easily, a pump is $50-100, a good radiator is $50-75, plus tubing, antifungal agent, fittings, clamps, maybe a reservoir... you get the picture. Watercooling gets expensive fast.
You might be better off swapping out for a single GTX or Ultra now and waiting for the newer cards to come out in October/November, but if it's a "must have it now" kind of thing, stick a couple of GTX's or Ultras in a EVGA 680i with a good 700+ watt PSU from one of the manufacturers I listed and you'll be good to go.
Hmm...good things to consider. I appreciate. I might hold off for a bit and wait as suggested.
In the meantime, i can start looking at things like power and case selection, perhaps even motherboard.
With those motherboards, since I already have 4gigs DDR2 800, looks like the A1 would be better since the memory standard is DDr2 800?
The case, ya, definitely want nice cooling and space... :)
The A1 and T1 are the same board. Only the bundle and warranty are different. Don't get an AR or TR revision board, though -- make sure it's a NF68-A1/T1. And yes, they'll take DDR2-800 just fine. That's what I'm running in mine. Make sure you update your BIOS right away if you plan to run 4 sticks of RAM, though. Earlier BIOS revisions didn't deal well with 4 sticks. EVGA makes it really easy -- they give you the option of downloading a ~10MB ISO that's bootable and updates the BIOS automatically.
The A1 and T1 are the same board. Only the bundle and warranty are different. Don't get an AR or TR revision board, though -- make sure it's a NF68-A1/T1. And yes, they're take DDR2-800 just fine. That's what I'm running in mine. Make sure you update your BIOS right away if you plan to run 4 sticks of RAM, though. Earlier BIOS revisions didn't deal well with 4 sticks. EVGA makes it really easy -- they give you the option of downloading a ~10MB ISO that's bootable and updates the BIOS automatically.
Nice...
These are the two boards?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188013
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188012
Nice boards.
The 520W is ok for SLI 8800GTS' with a dual core. The quadcore would push it over the top, imo. The 620W is still pushing it with GTX's in SLI and a quadcore. I'd definately go for the 750 Quad PSU instead, or the ST85ZF.
Dual 22's wouldn't need SLI. A 24" would make better use of SLI GTX's, but a single GTX is more cost effective than GTS' in SLI.
Yes, those are the boards. Go for the A1, for its lifetime warranty.
Another case option would be the CM Stacker.
Have played the World in Conflict beta dual monitor setup rules. Get the dual 22"...
I like the CM Stacker 832 Case..
silent and eng both helped me see the light of getting one Ultra.. There are several on the egg w/ rebates for around 579.99..
I would shoot for 24" monitors at a minimum if you still want to do SLI..
There's an XFX Ultra for $550 after $50 MIR with free shipping at ZipZoomFly, and probably better/similar deals elsewhere. The Egg doesn't /always/ have the best prices (as I have sadly learned only since making that mistake myself two months ago...)
I looked for that one last night per your suggestion and it was out of stock unfortunately.. They may have gotten more in @ ZZF today though..
Ya, i started to play the beta as well. pretty cool.
I know supreme commander has dual monitor support and I see that has a growing trend for RTS games...
However, if SLI is not supported on dual monitors, how demanding would dual 22" monitors be and what would be needed for very nice visuals (high details for instance)
I'm thinking squarely in the category of "too demanding" in 4-6 months time. Certainly too much for one card. I really do think you'd be better served with a single 24".
