Suggestions for new/replacment pc
ttodd1
Looking to upgrade my son's pc with new build. Currently he has a Intel Core Duo E4400, MSI P6N Platinum motherboard, 2gb RAM, pair of nVidia 7900 GS KOs in SLI
with a 250 GB HD, power supply is a cheap one from local store (bought in a pinch).
Any suggestions?
surfing, gaming, streaming videos,email, some video editing
under $1000 - the lower the easier on the wallet ;)
3) Where do you live?
SC
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
case,cpu,motherboard,ram.power supply,video card,HD
DVD/cd drives
6) Will you be overclocking?
maybe
using a Sony Bravia KDL-32M3000
asap
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
not sure
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
have XP pro but want to move to Win7 64bit
$285 - Intel Core i5 750 CPU + Gigabyte GA-P55-USB3 Intel P55 ATX Motherboard Combo
$62 - G.Skill F3-10600CL9D-4GBNT 2 x 2GB DDR3 1333 RAM
$180 - Gigabyte GV-R685D5-1GD Radeon HD 6850 1GB PCI-E Video Card
$150 - Corsair 650TX 650W PSU + Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive Combo
$160 - Cooler Master CM690 II Basic ATX Case + Windows 7 Home Premium 64bit OEM Combo
$160 - Acer G235HAbd Black 23" Widescreen LCD Monitor
Total: $997 plus shipping
Note that the combo deals end on October 31st.
I wanted to say thanks for the specs. I finally got it all together and it is running great. I got a Cooler Master HAF 922 case instead (was only $10 more) I did have to redo a couple of the combos but still got everything for about the same price. The video card was hard to get cause every time I went to order they were sold out. The cpu temps idle around 24 and under load get about 57. Way better than the E4400 that ran quite hot. Again thanks for the help.
