DarkStar_WNY
- Dec 27, 2006
General use and lots of gaming
I can probably go up to $4k or so.
Fredonia New York (Western NY)
Case (currently planning on Caselab SMA8) and everything inside it, I will be getting the mouse, keyboard and monitor will be taken care of separately.
I'm thinking a 980 ti for the GPU, a mid sized SSD for the OS, a 1TB SSD for games and a larger WD black 2 TB drive for storage (I have a Qnap NAS for any other bulk storage.
I wont be reusing anything.
6) Will you be overclocking?
Yes
Leaning toward the Acer 27" Predator 1440p monitor
Probably about 60 days from now as I'm waiting to see how Skylake processors perform, as well as the Z170 mobos. But I could decide tomorrow to order all the parts and build it ASAP also.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB3.1 would be nice, and I will want the option of adding a second GPU, other than that I need a decent overclocking board, especially as I will be making a custom loop for this rig, just not during the initial build.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
No, will need new OS key as I'm rebuilding my current rig for my wife.
Yes
