Suggestions for my build to overclock...
well... you're already planning to OC i assume... so maybe get a cheaper CPU and memory set, and get a better graphics card to even it out a lil...
I chose the CPU because it was the slowest CPU with 4MB of shared L2 cache. I am not sure what to use for memory, I have read that having quality memory is important so I went slightly on the high end for that.
Edit: do you think the extra L2 cache makes much of a difference? or is it a waste of money?
I am not wanting to spend any more money on the video card then that due to problems with Vista. While I am not planing on using Vista anytime in the near future I am sure I will switch over in the lifespan of this PC. Since Vista seems to have large problems with graphics cards and card performance I am anticipating that there will be a lot of new cards on the market in the next 6 months that solve these issues. If the issues were small and easily fixed with drivers I am sure they would have already done so. So I am choosing that card with the intent to upgrade it in a year.
I use these in my DQ6, not a problem one, results in my sig. Also note the commitment by Corsair to customer service. Corsair reps also monitor the Memory sub-forum of [H].
http://www.newegg.com/Product/Product.asp?Item=N82E16820145034
You just want to stay away from stuff that requires more that 2.1 volts to operate. Bios updates have mostly solved that issue with all P965 boards but better safe than rma. The Geil would be ok as well.
Mine ran 4 4 4 12 to about 450FSB then I had to move to 5 5 5 15 which was good to 480 FSB and then went to auto to get that last stable 5MHz FSB. With your higher mulitplier CPU you will not have to do any of that.
Thanks, I switched the memory to what you had. As the price is the same between that and the Gskill (after rebate anyway) I think I will go with the name I am more familiar with. Thanks for the suggestion.
