DeathPrincess
- May 15, 2010
Ive never made a custom case before, but ive done lots of other "creative" things, such as scultpting (horror/cyborg minatures not sculptures). So i'd like to use that experience. I'm fine with sculpting, but not so fine with other DIY things (maily because I don't own a saw or drill, but I could use one if I had to). SO i'm going to be sculpting the whole outside based on a prebuilt case. (lazy?)
Anyway design!
It did it in 10 minutes with a purple pen! bwhaha. I zoomed in lots to make it clearer. (ignore the doodles and that I don't have a ruler)
I'm purple and green obsessed. So thats the color scheme, with black as a main.
To fix the face on the front i'm using a hinged front door. (i'll fix the tubes on with magnets). So the driives can be opened. (practical). I have a lexa s case that shall do fine (and its cheap)
But here is the problem. I'm used to working on smaller things. maximum of about 12 inches. Covering a whole case in the usual materials would be very costly (8$ for about 300g). So my question is, is there any easily availible sculpting material thats durable enough to cover a case in. (im clumsy) and can be painted filed etc, and is cheap? I've heard of something called milliput, but i'm not sure how strong that is.
I've got a load of tubes and wiring from various other things I do, so they wont have to be done,mainly just the face and detailing.
Anyway design!
