Suggestions for cheap build ~$300
Knuit
Hey all, I'll be pricing out a cheap build for one of my little sister's friends this weekend and was curious if anyone had any suggestions as I haven't shopped the low end for a while.
1) What will you be doing with this PC?
Basic web browsing, youtube, word processing
~$300. The cheaper the better. Yes
3) Where do you live?
Michigan, US
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
Case/PSU
RAM
CPU
MOBO
HDD
DVD drive
Integrated video should be good enough.
I have an old CRT they'll be getting and they already have a keyboard/mouse
6) Will you be overclocking?
Nope
N/A
Within the next 1-1.5 months
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Nothing in particular.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Will probably just slap an old XP 32bit I have on it.
In this case, a pre-built or a netbook would be a better choice. This is because a minimally acceptable PSU by itself (to handle anything modern) would cost $60 or more by itself. This would leave no more than $240 for the rest of the build. And given the cost of a decent CPU/motherboard combo being about $140, that leaves only $100 for the case, RAM, HDD and DVD drive combined. And I would not trust Windows XP 32-bit these days on modern systems not only because they cannot use more than about 3GB of RAM, but because even Service Pack 2 is now no longer supported by Microsoft (besides what had already been archived). This means that if you continue to use XP, you will have to update to the still-buggy Service Pack 3 in order to receive any further security hotfixes at all. And if that old copy of Windows XP is still of the original 2002 release (pre-Service Pack 1), you cannot format more than the first 137GB of your system's hard drive on Setup. As such, within the $100 to $120 budget on the case, RAM, HDD and DVD combined, there is no room at all whatsoever for more than 1GB of single-channel RAM (after accounting for the case, HDD and DVD), which would not cut it at all for any modern, up-to-date program.
In other words, $300 is barely enough for a really shitty PC unless you're going for a pre-built, nettop or netbook. You'll have to up your budget to more than $400 for us to configure even a minimally acceptable custom (BYOPC) build.
Considering that you're not planning on building/buying this PC until a month to 1.5 months from now, I recommend coming back when you're only two weeks away from building/buying this PC. Whatever parts we recommend now may not be the same parts we recommend in a month to 1.5 months from now to due to parts becoming outdated, outperformed, or out of stock.
EDIT: I do have to disagree with E4g1e's statement somewhat:
$115 - AMD Athlon II X2 260 CPU + Biostar TA785G3HD AMD 785G mATX Motherboard
$35 - Patriot PSD32G13332 2GB DDR3 1333 RAM
$46 - Western Digital WD5000AAKS 500GB 7200RPM SATA 3.0Gb/s Hard Drive
$17 - LG GH22NS50 DVD Burner
$50 - Antec NEO ECO 400C 400W PSU
$30 - Rosewill R102-P-BK 120mm Fan MicroATX Mid Tower Computer Case
Total: $293 shipped.
Note that the combo deals and prices for the above parts are only good for another week or two. Though I agree about the Windows XP
