Currently I am running a Thermaltake Toughpower 700W PSU
It was stripped from my old computer to save on upgrade costs. It has been powering my
whole system.
790i Motherboard
4GB DDR3 Ram
8800 GTX Vid card
3 harddrives (1 velociraptor, other 2 just normal SATA)
E6750 CPU (2.66 Ghz Core 2 Duo)
I am looking to over the next 6 months upgrade from this to.
GTX 295 (and later 2x)
(will always have 3 Hard drives, maybe 4. Might get another velociraptor).
Q9650 (or maybe better depending on prices). ( at least some fairly nice cost effective Quad core instead of dual.)
What I am wondering is, will that 700W be enough for 1 GTX295. (including its unique Amp requirements and voltage requirements), or would an upgrade be needed for running one. And if an upgrade is required to run 1. or, for future proofing for when I get another, what PSU would be suggested? And what PSU companies do you guys find to be the best. I am hoping to only have to plop down 250-350 for the PSU, as ive seen some expensive PSU's for 500, If you can find a great one that suits my needs for less thats even better.
Thanks in advance.
Xisdibik
whole system.
790i Motherboard
4GB DDR3 Ram
8800 GTX Vid card
Thanks in advance.
Xisdibik
