Suggestion for mITX with....
Phrik
I'm looking for an ITX board with at least 6x SATA ports...any of yous have a suggestion ? I will only be putting the 6 HDDs I have for data storage, and run XP on it, and just do a simple share. No fancy NAS features needed. Just something reliable, fast enough to provide offer the HD playback needs, music playback and etc.
I'm already looking through at the moment, but have not found any.
I do prefer something like an Atom-based, so I don't have to buy the whole bang anymore. I've had an old AMD based setup for it but the motherboard died out now. So I'm planning on re-using the RAM, PSU, and some minor stuff.
I had a GA-MA78GM-S2H (rev.1.0), so if it's an AMD-based ITX board I can get, then I can hopefully re-use my CPU with it.
So, if any of yous have a suggestion or know of an ITX board with 6x SATA ports, that will be greatly appreciated !
i was looking at something similar a few days ago.
i think the Zotac H55 'WiLLiSTER' suggested is the best solution i found as well (at least for a decent CPU/ITX combo that is). there are a number of other intel based mITX boards (socket 775 & 1155 with 6xSATA). see full list of zotac mITX boards here (need to sort by form factor on site);
http://www.zotac.com/index.php?option=com_wrapper&view=wrapper&Itemid=100026&lang=en
the rest are atom based which personally i think is horrible under-performing piece of technology.
there are some socketed AMD boards but they are limited to 2 to 4 SATA ports. there is one decent AMD mITX board (E350 Zacate APU);
http://www.sapphiretech.com/presentation/product/?leg=&psn=000102&pid=1034
it has six SATA ports (5x SATA III, 1xeSATA). don't think it has RAID tho but since you don't care about 'fancy NAS features', not an issue.
I've looked at the Zotac stuff, and if I'm going that way, I'm gonna be spending more than I would want to. That would mean the board, new CPU, new RAM = $$$$$
I'm still looking for more Atom based which can only mean new board, CPU included, re-use RAM (possibly) = $
or
AMD based, which can possibly mean new board, re-use CPU (hopefully), re-use RAM (hopefully) = $$
Anyway the CPU I currently have from the old box is an Athlon X2 4850e, if this helps.
But so far, not much found potentials...... specially I'm trying to make this very low budget.
Well if you're not gonna use the PCI-E x1 slot for anything, you could always go this route:
$55 - ZOTAC NF6100-E-E Nvidia nForce 430 MCP Mini ITX Motherboard
$33 - SYBA SD-SA2PEX-2IR PCI Express SATA II (3.0Gb/s) Controller Card
Total: $88 shipped plus tax.
The above would let you reuse your RAM and CPU and is probably your cheapest, albeit lesser quality and slower than your current Gigabyte mobo, option if you want mITX and 6x SATA ports.
For comparsion, these are the only mITX mobos I found on Newegg that have 6 x SATA ports:
~$130 - Zotac H55ITX Motherboards
$238 - Zotac M880GITX-A-E AMD Turion II Neo K625 AMD M880G Mini ITX Motherboard/CPU Combo
$208 - Supermicro MBD-X7SPA-H-O mITX Intel Atom D510 Motherboard
Otherwise, if none of the above options appeal to you, then ITX is not the route for you.
