Sub $500 Gaming Build
FRAGMAN BOB
This is for my dad, He is looking at getting a new computer. He isnt a hardcore gamer but enjoys his FPS and racing sims. He just needs a new motherboard, CPU, RAM, and Videocard. Nothing fancy is needed, no RAID or SLI needed. Everything else is reusable.
I spec'ed out this:
Newegg combo, X2 5200+ w/2x1gb Geil PC6400: $189
Asus M2N-E SLI (not up on motherboards for amd, just grabbed one with good reviews): $89
BFG Tech 7950GTOC 256mb: $179
Total:$459
Also he would prefer to stick with AMD if its not a huge price/performance difference. thanks
I can't say it's original, but here it is anyways:
$66 - AMD Athlon 64 X2 4000+ Brisbane 2.1GHz 2 x 512KB L2 Cache Socket AM2 Processor - Retail
$80 - BIOSTAR TF560 A2+ AM2+/AM2 NVIDIA nForce 560 MCP ATX AMD Motherboard - Retail
$70 - A-DATA Value Series 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
$290 - EVGA 320-P2-N811-AR GeForce 8800GTS 320MB 320-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card - Retail (less $20 MIR)
I would go for that spec ^, it is a nice spec yet cheap. But, I would change the 8800GTS to a more subtle card, like the X1950 Pro, or you could try looking around to see if you can find an X1950 XT anywhere.
psu will probably be upgraded to regular 500 or 600 watter. monitor is a 22" acer lcd
I agree with Danny, and you should look into at least the 8800GTS 320MB. The lower vram wouldn't allow for such high detail, but the DX9 performance definately be better than the 7950GT.
