Sub-$500 Build for my Cousin
PC_User
I'm making a birthday build for my cousin and wanted to run it by you guys. The budget is $370 for the parts that I need.
Mostly games (UT3) & web browsing
$370 total (including shipping) for the parts needed (see #4)
3) Where do you live?
Parts sent to Washington. No taxes from Newegg.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, Motherboard, RAM, HDD, Case, PSU, DVD-ROM
ATI Radeon 4850 512mb + Thermalright HR-03 GT
6) Will you be overclocking?
No.
22" Samsung - 1680x1050
Now.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Nothing in particular.
10) Do you already have a legit and reusable/transferable OS key/license?
Yes. Vista x64.
Here's what I came up with so far:
$70 - E5200
$80 - Gigabyte EP43-UD3L
$48 - 4GB G.Skill DDR2 800
$40 - Seagate 160GB 7200.11
$100 - Antec 300 + Antec earthwatts 380W Combo
$23 - LG 22X DVD±R DVD Burner
TOTAL: $379 (shipping included)
AMD is not my specialty so maybe you guys can suggest something for the same budget.
looks like a good system to me. i would shy away from seagate drives for the moment...if you could increase budget a tad........i like the wd cavier black its around 60 bucks. what vid card are you going to use? sure 380 watts will be enough? i think there is a corsair 450 watts for like 60 bucks or something on newegg.
No o/c, this AMD build should spank an E5200
CPU/MOBO - AMD Phenom II X2 550 3.1ghz Calisto + Asus M4A78 Plus AM3/AM2+/AM2 AMD 770 for $162 ($10 MIR on mobo)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.200020
RAM - 4GB G. Skills DDR2 800 for $48 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
HDD - Western Digital Caviar SE16 WD3200AAKS 320GB for $55 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136074
CASE/PSU - Antec 300 + Antec Earthwatts 380 for $90
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.196654
or
Case with PSU - Antec NSK 4480B II Black with Antec 380 for $90
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129060
OPTICAL: LG 22X DVD±R DVD Burner for $23
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
Total: $378 before shipping
Video card is listed as the part I'm reusing. It's a Radeon 4850 and the 380W will be enough. Also, he doesn't need a large hard drive so 160GB is more than enough. I'm sure even 80GB will be enough but the difference in price is negligible.
HardwareGuru, thanks for the AMD suggestions.
Any other advice/build suggestions?
I don't think there is any combo or configuration that can match that AMD X2 550 build. Especially considering this at stock speeds its a good performance boost over an E5200. An X2 550 3.1ghz Calisto cpu matches up nicely to an Intel Core 2 Duo E7400 at 2.8ghz. In gaming, it has the edge over the Intel E7400
What about compared to the new E6300?
In gaming, the X2 550 will beat the Intel E6300. The E6300 is basically the same cpu as the E7400 but with 2MB L2 cache as oppose to 3MB L2 cache on the E7400. Yet, the X2 550 cpu already outperforms the E7400 cpu in gaming.
You can O/C X2 7750 Kuma or Intel E5200 cpu to 3ghz speeds. But, PC User mentioned no O/C on this build.
honestly I'd buy used ram, and hardrive off the forums :) they're both crazy cheap. 500Gbs satas go for 40-50 bucks. 4gb of ram would run you 25-30. Might be able to score a decent Optical drive aswell.
its also worth noting that the 320GB drive will be substantially faster than the 160GB one, and I'm amazed that hardware guru was able to cram a deneb (crippled as it is) into that configuration, thats pretty sweet, I'd go for that for sure.
The new WD 160GB drives should be single sided 320GB platter drives, so they should be fast. I agree, stay away from Seagate 'cudas.11 for sure, and 12th gen as a precaution, lol -- bricks are no fun.
I know you love Intel PC_User, but go with the PhenomII X2. :p
