HTPC, Music, hulu,netflix
Between $300-400 preferably closer to 300
3) Where do you live?
Pittsburgh Pennsylvania
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything minus monitor, mouse and keyboard
N/A
6) Will you be overclocking?
Not unless I need to
1080p/720p
Soon May at the latest
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
None of these needed
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
yes 7 64bit
I would like a htpc, preferably in a smaller case like this antec one
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129046
Unless someone has a better alternative.
I would also like a tv tuner that would allow me to record tv. Does anyone know of any that will allow me to add a cable card to the tuner.
N/A
1080p/720p
yes 7 64bit
