mycomputersucks
- Oct 31, 2001
I'm looking for something to, primarily, use as a mobile entertainment system. It will be used to entertain kids while otg so it needs enough processing power to playback multiple media formats including 1080p Hi10p and HEVC.I want something small (11 to 13 inches), light weight and w/ good battery life(6+hrs). A 1080p(most of my rips) screen would be ideal but this doesn't appear common in those screen sizes/price and overall screen quality is more important than resolution. i'm fine w/ using removable storage but preferably usb 3.0.
This is replacing an aging Atom Z3740D 8 inch tablet which can choke on high bitrate 1080p content unless specifically encoded(lame) and had very limited storage options. Not to mention win10 is terrible w/ just a touch screen.
so, the question is which SoC architecture and os?
An Atom based system like the lenovo 100s? A celeron systems, like the hp stream, look about right if they are braswell based since that apparently has 4K/H.265 video acceleration so 1080p *should* be a breeze. Any AMD solutions to look for?
As for OS, windows will give me more software options but is more of a resource and battery hog. How is chromeOS's offline video playback? and chromeOS driver support to maximize gpu hardware acceleration?
thanks for the opinions and info!
