Activate: AMD
- Nov 6, 2004
I'm currently having problems on some BD-rips (re-muxed the m2ts to .mkv w/ lossless codecs) with my E-350 based htpc.
symptoms:
1) Stuttering sound and video, occasionally it will smooth out for a second.
2) ~50%-70% CPU usage
3) Doesn't occur universally on all video files. I believe I may have it narrowed down to VC-1 encoded films. Will check again this evening to confirm
Setup details:
1) MSI E-350, 4gb ram, 60GB SSD w/ win7 pro 32-bit
2) Downloaded and installed the most up-to-date drivers for the rig on AMD's website
3) Shark's codec pack installed. issue occurs with both WMC built-in player and in MPC-HC using ffdshow
4) All video files are being streamed over GbE by my fileserver. No issues playing back movies from this rig on any other PC, if the streaming is an issue its on the client side, not the host
It seems like something isn't being accelerated properly, but if that was the case I would have expected to see CPU usage pegged and it isn't. MPC-HC says its using DXVA. anything I should check?
symptoms:
Setup details:
