stupid DVI mode... damn 710t... blah
ciM2pHat4U
Got a new Samsung 710t and it works well in analog mode, but when I toggle source to digital mode, I get a black screen and the little green light by the power button flashes at me defiantly. However, I do not get the check-input-connection dialog box that I do get as soon as I pull the cable out (meaning the monitor knows the DVI cable is plugged in, just doesn't show me anything). The digital in did work before, but it just doesn't work now after I reinstalled WinXP. Anybody know the fix?
Using samsung 710t, radeon 9800pro, abit ic7-max3, p4 2.8E @ stock (and yes I did check to make sure the cable is plugged in properly, the power is turned on, etc...)
Anyways, all help is appreciated. Thanks in advance
btw, please have a nice day (and nice life (and afterlife)) too. And also be happy and be healthy. And also some good fortune to you. And your family.
try booting up the computer with the lcd plugged into your dvi output
That's what I've been doing, haha how else could I get a digital input. When I was first setting up my system (after building it), I had both analog and dvi cables hooked up between the 710t and my 9800pro, and I could switch between them no problem. Then I crashed my system so I reinstalled WinXP but now only analog works (I still have both analog and dvi cables plugged in though, and I've tried taking out one or the other too).
The strange thing is that when switched to digital, the screen is black (as in unlit/unpowered black), and the little green light blinks, but if I pull out the DVI cable then the screen lights up and gives me the check-input-connection message. If I put the cable back in, it goes back to being unlit/unpowered. I can, however, toggle back to analog normally.
Try making sure you didn't increase your refresh rate to a point where the montior can't work. Set everything back to "60" in your video settings..see if that helps.
Luck
BillR
Luck
BillR
It's been at 60 the whole time. Same problem =(
WickedWeasel said:
Try installing a different ATI driver.
This looks similar to the boot up DVI LCD problem.
Do you know where I could find information on the boot up DVI LCD problem?
