Student/light gamer build
kinghippo
Mostly working with MS Office, CS5 After Effects, Photoshop, Illustrator, and Dreamweaver. I will be gaming when I get the chance though. I don't need SLI, just one beefy card should suffice.
800 USD 1,000 at the most
3) Where do you live?
Indiana
CPU - I'm wanting to go with AMD. The price is right, but I don't know how well AMD gets along with Adobe?
RAM - I'm thinking 8 gigs should be fine?
Motherboard - Need a new one.
PSU - Need a new one.
Case - I'm considering the Bench Dragon from myopenpc. I like the idea of being able to clean off my pc without having to open it up. .
Video - I have an 8800GTX I can use now, but I don't know if I should upgrade or not? I'm happy with the performance on my current rig and it would most likely perform better with my new setup.
Sound - Creative X-fi Fatality
HDD - Happy with my hard drives.
6) Will you be overclocking?
Yes, just because it's fun.
Currently using a 24 inch 1080p I-Inc. Would like to upgrade to dual monitors.
May or June.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
I would prefer to go with a board that works well with a Nvidia GPU. I'm not sure about all the features I need. I definitely want USB 3.0 and SATA 6Gb/s.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, I'm using Win7 Unltimate 64bit student version.
Any advice would be greatly appreciated!
May or June.
Too soon to start planning a build. A lot can and will happen in the PC market where many of our hardware recommendations will be invalidated. So your best bet for up to date advice is to post another build thread 2-3 weeks before your actual build/buy date.
With that said, if you were building this month, AMD would not be a good choice due to your budget: you can easily fit a significantly faster Intel Core i5 2500K CPU in that $800 budget. However the 2500K may not be a good choice 2-3 months from now depending on how well AMD's new Bulldozer CPUs work out.
Yeah I guess that is quite a long time in the pc world. I think i'm just getting anxious to build.
I'll do some research on AMD and Adobe in the meantime.
