Streaming Device - 1080p from PC to TV flawlessly
Discussion in 'Home Theater PCs & Equipment' started by topslop1, Mar 31, 2018.
  1. topslop1
    topslop1 2[H]4U
    3,131
    Apr 15, 2002
    Looking for a streaming device that will stream my PC to my TV flawlessly wireless.
    Something that would handle a high detail 1080p movie streamed to the TV without any studdering or slow downs or detail loss.
    Does this device exist?
  2. Tekara
    Tekara 2[H]4U
    2,500
    Jan 6, 2003
    Basically all the things do that:
    AndroidTV / FireTV / Roku / Nvidia Shield streaming box
    Home Theater PC front end
    Chromecast / Miracast / WiDi / Wireless AV transmitters
    DLNA/ SMB / Plex / Kodi share to a smart TV or streaming box
    If it is a smart TV, you may even be able to add it via "Devices and Printers" within Windows.
    1080p isn't demanding, so any of the above would be able to handle without issue provided you have a more modern wireless setup like N or AC or go with something like the wireless AV which uses their own signal.
  3. SixFootDuo
    SixFootDuo [H]ardness Supreme
    4,626
    Oct 5, 2004
    I will help you out and point you in the right direction saving you both time and money.
    1. Download and install Plex Media Server. Easy to setup. This is totally free software. When you get the paid services page that pops up at the end of installation, do not let it confuse you. Close the window and proceed to the setup options.
    2. Buy you a Roku Premier. $75 or so dollars on Amazon. Or the Roku Ultra for $99 and possibly even cheaper using Facebook marketplace and or Craigslist to find one. I suggest you DO NOT BUY anything other than the Roku Premier or Roku Ultra. While you can accomplish the same goals with the Roku sticks, the performance is not there and you lose valuable time performing tasks along the way. I've also had wifi streaming issues using sticks. I've never had problems streaming 4K content with the Premier or Ultra.
    3. Hook up the Roku to your TV. Plug in the power and HDMI cable and go through the setup. Here you will pick your channels, config your wifi etc. Make sure to pick the Roku channel. You can also sort your channels the way you want them.
    4. Once Plex is installed and your library is in place, simply turn on your TV, go to your Roku, select the Plex channel and decide what movie you would like to watch.
    5. Turn off the lights, get comfy and enjoy your movie.
    Total cost is $75 to $100 dollars. Setup time is around 10 minutes for everything. Level of difficulty, 3 out of 10.
    Pro Tip: To add additional value to your setup for not a lot of money buy you a Google Chromecast and a Google Home Mini. You can then use Chrome on your mobile device to stream most video sources. You can also use voice commands to have your Google Home Mini play videos for you over your Chromecast. You can find used Chromecasts and Google Home Mini's all day long for cheap on Facebook Marketplace and or Craigslist.
    I think I paid $10 for Chromecast and $20 for a Google Home Mini.
    You can do all of this cheaply with amazing results. It's not complicated. I've been streaming for over 12 or 13 years. It's so easy and cheap in 2018. Dirt cheap. With a little effort, time and money you can end up with results that will not only impress you but you're Friends and Family as well.
    GoldenTiger likes this.
  4. Vengance_01
    Vengance_01 [H]ardness Supreme
    5,503
    Dec 23, 2001
    Are you looking to stream exactly what's on your desktop or just media content stored on your desktop?
    Aireoth likes this.
  5. MrGuvernment
    MrGuvernment Pick your own.....you deserve it.
    19,751
    Aug 3, 2004
    I grabbed a Nvidia shield lately, hadf a remuxed 4k movie and i was suprised...i was streaming it over AC...NOW...every about 20mins or so, it would stop to buffer but ya.. i am sure it could handle 1080 over AC.
    Solhokuten likes this.
  6. Solhokuten
    Solhokuten [H]ard|Gawd
    1,051
    Dec 9, 2009
    Nvidia Shield TV
    staknhalo likes this.
  7. westrock2000
    westrock2000 [H]ardForum Junkie
    10,329
    Jun 3, 2005
    Most devices can play the actual media just fine. It's often in the interface you will notice the differences. The Apple TV has been the smoothest interface device I have used (I haven't used dozens of different models, so don't counter). Buttons are responsive. But that comes with some adjustment. Part of the Apple smoothness is the expectation that media will be exactly as it expects it to be....which is fine if you are just now making the switch to a digital library. It could be a bear if you already have 100 MKV's ripped.
    1080p "high bitrate" only needs about 3-4MB/s to stream, so don't worry if it's not gigabit connection. 4K h265 isn't much higher on bandwidth needs. So if the device only has 100mb network plug, it's not a problem.
  8. Cylocybin
    Cylocybin Limp Gawd
    135
    Jun 3, 2018
  9. boss6021
    boss6021 Limp Gawd
    320
    Oct 11, 2006
    Another vote for Nvidia Shield TV. After purchasing and testing Amazon, Apple, Roku, and various Android boxes, this was easily the best in terms of features, content, and flexibility.
  10. Cylocybin
    Cylocybin Limp Gawd
    135
    Jun 3, 2018
    its so much more expensive what can it really do thats better
  11. mnewxcv
    mnewxcv [H]ardness Supreme
    5,838
    Mar 4, 2007
    Steam link for $10!
    N4CR likes this.
  12. ob1
    ob1 2[H]4U
    2,276
    Apr 17, 2000
    Chromecasts suck, I gave like three of them away. The fire sticks are just OK, at least they have their own remote. The fire TV boxes are better, meaning faster responding and more support for direct play. The shield plays everything so far from Plex. Nothing compares to the support for video playback. Never used a Roku or Apple. The shield also has games, can mirror your gaming PC, so you can play your PC games through the shield on your big screen, (letting getting lit and playing quake on the 65" like I'm a kid again). I have fire tv boxes in the bedrooms, testing a fire cube, but on my main TV in the living room it is shield all the way.
  13. boss6021
    boss6021 Limp Gawd
    320
    Oct 11, 2006
    Everything! $179 (not on sale) for this device is a steal. From it's ability to stream games from either Nvidia Experience and Steam, or right from Nvidia's servers to it's ability to stream almost any service (no iTunes, but who cares?). It can host Plex on it, great emulator support for classic gaming, has access to the Play store, and sideload apps if you prefer that, full controller support (Nvidia, PS4, Xbox One), add USB storage for Plex or other media, fast responsive interface, and during testing the only device to pass full audio through. This is in my opinion the only option for media playback and living room gaming. Show me another device that even comes close to this at this price point, and design!
    brucethemoose likes this.
  14. atom
    atom Gawd
    771
    May 3, 2005
    If you have an Xbox One or PS4 you can download Plex for them. Bam.
  15. boss6021
    boss6021 Limp Gawd
    320
    Oct 11, 2006
    Yes, if you have an Xbox One or PS4 and want to use it for this purpose. The lack of features and crap UI killed them as options for me.
  16. Stoly
    Stoly [H]ardness Supreme
    5,705
    Jul 26, 2005
    +1 on the shield if you intend to do much more than just streaming
  17. Verge
    Verge [H]ardness Supreme
    5,760
    May 27, 2001
    Uhd discs can peak over 100mbut, not to mention tcp overhead.
    100mbit simply won’t get the job done.
