Strange Internet Disconnection
maxamillion
Here is my problem. It seems like everytime I'm downloading a larger file for a long period of time, my ethernet connection to my router/modem would somehow get disconnect and I would lose all internet connections. If I wanted to log on again, I have to restart my entire pc..... So does anyone know what is going on?
More info? What kind of NIC are you using? If NF3/4, do you have the Nvidia firewall enabled (if so, turn it off :) )?
I'm using the marvell yukon nic that's included on this motherboard and I have no firewalls installed (windows firewall is also disabled). I have also experienced same conflicts with nvidia's nic.
If you have problems with both Nvidia and the Marvell, then it might be a problem with your router. Maybe bypass the router right to the modem and see if you have problems that way.
That's the problem, the error seems to occur both ways. Nothing like this has ever occured until I got my raptor hard drive or could it be the motherboard?
Another thing, I remember installing nod32 (anti-virus) and IDM (internet download manager). I can't blame these programs for the error but could it possibly affect my internal system configurations?
Note: I just disabled the 1394 Connection found in my network connections and see if that would make a difference in the long-run.
