Strange happenings are afoot..
spiff967
Hey, first post.
I bought a custom-built PC back in August that has been, for the most part, excellent.
Specs:
Intel i7-920 Stock @ 2.66
Mobo: Asus P6T
Graphics: EVGA GTX 280
Asetek LCLC Water Cooled
6 GB DDR3-1333 RAM
1 TB Drive @7200 RPM
Windows 7 Home Premium x64
Raidmax Sagittarius II Case
Blu-ray Drive
Hooked up to:
Dell 2309W 23" 2048x1152 resolution
Issue:
So, for the last few months I've been observing some strange behavior...
1) After a few hours of use (varies from 6 - to over 24), all the applications start to get really sluggish. Meaning, say I open a new tab in Chrome, or click on the start menu, etc, it takes a few seconds to get going. Nothing that I can't handle, but it damn well shouldn't be happening.
The problem goes away if I restart my computer, but I don't want to, and sometimes can't if I'm in the middle of something important. I check the system resources tab in task manager, but CPU is always at <5% usage, so it's not like any processes are utilizing a majority of system resources.
2) In the middle of games, sometimes after 20 minutes, sometimes after 2 hours, I start to hear crackles in the sound, leading to, if I don't quit the game, complete system freeze-up, and usually BSOD's. Now, this is, IMO, a much more serious issue than (1), but neither should be happening.
I usually get a secondary clock interrupt error in the BSOD message, with nothing appearing in my action center ex post facto. I've also tried various prior drivers (for the GTX280, mostly), with both issues occurring regardless of what driver version I've attempted to use.
Now, this computer is, for the most part, completely perfect. However, with the two above issues, I feel like the lifetime of my computer is somehow being affected. I've opened my case up and made sure everything is seated properly, so I'm reasonably certain that that isn't an issue. I've also run RealTemp w/ Prime95 and Furmark. While my temps are sometimes unusually high (~80C), I think that has more to do with the ambient temperature in my room being pretty high. Even so, 80C is well within the operating range of these components.
Can [H]ard please help me? If these issues are solved, I will be eternally grateful!
The symptoms, especially issue number 1, sound like a possible memory leak. Run memtest for at least a dozen passes. The system temp should be addressed as well, 80°C on a water cooled rig is way too hot.
Oops, typo. The upper end of the temps run around 55-60C. It hits 80C when I OC'd to ~3.6 Ghz.
I'll try running memtest...
@Danny:
It's an 800W PSU
Btw, I was looking at your thread just a second ago - have you ordered your rig yet?
It looks...beastly :)
@Danny:
It's an 800W PSU
Think you got me confused with someone else. I'm not building a new rig anytime soon..
Which 800W PSU?
Hmm okay. You may have commented on it then, and I just spaced.
I've run 15 passes of memtest86+, with 0 errors reporting. It's just standard Ultra Cyperpower 800W PSU. It's not a major name brand. Is that an issue?
Hmmm, well a shitty PSU would explain issue 2. As for issue 1, reformat and reinstall the OS just to rule out an OS issue.
Posted via [H] Mobile Device
[Testing the Hard Drive]
Download the CD image of Hitachi Drive Fitness Test, burn the ISO file to a CD, and then boot from it, just like you would do with the XP/Vista install CD. Test the hard drive and see if any problems are found. DFT will run on most manufacturers' hard drives. Alternatively, you can use Seagate's SeaTools for DOS to test a Seagate or Maxtor drive. For a Western Digital drive, you could use Data Lifeguard Tools for DOS to test a Western Digital drive.
[Testing the CPU]
Use Prime 95, OCCT, Orthos or Intel Burn Tool to stress test the CPU.
[Testing the GPU]
Use Furmark or ATI Tool to stress test the GPU. If you see any artifacts, the GPU could be overheating, too overclocked, or faulty.
[Testing the PSU]
Buy and use a digital multi-meter to monitor the voltages coming from the PSU. Follow the instructions for "Using a multi-meter to check voltages":
http://www.bfgpower.com/troubleshooting.html#DMM
Everything normal...I haven't tested the PSU, since I don't have a multimeter. Maybe I should just get a new one?
I just cleaned out my computer two days ago, and its been running well since. There was a bunch of dust on the water reservoir, so maybe that was the issue?
