kingnothing83
- Dec 5, 2006
I recently made a system and when i powered it on the fans started to spin up, and the hdd light came on at the front but then it instantly turned itself off. Also, there was a 3 second gap between pressing the on button, and the system turning on. I tried a few things to work out what was causing this problem and read about other users having IDE problems. So i unplugged the IDE hard disk and it booted fine. I then installed the latest BIOS and installed the jmicron drivers. I then plugged the IDE hard disk and it worked, but then the next time i tried to turn it on I got the same booting problem.
So the problem seems intermittant, also sometimes i press the on button and it boots instantly, sometimes there is 2-3 seconds where nothing happens then it turns on. Any ideas what the cause of the problem is? Maybe i dont have something plugged in properly, the motherboard is faulty, the psu is faulty, or theres a compatibility issue with the system? Thanks
MSI P965 Neo
Core 2 Duo E6400
Antec Neo 500W PSU
Antec solo quiet case
2x DDR2 800Mhz PC2-600 RAM
PX7900 256MB Video Card
Seagate 7200 SATA Hard Disk
Maxtor IDE Hard disk
DVD rewriter
Soundblaster XFi
MSI P965 Neo
Core 2 Duo E6400
Antec Neo 500W PSU
DVD rewriter
Soundblaster XFi
