strange beep code on booting w/ P5W DH?
mickey
Just built a system using the ASUS P5W DH Deluxe (like a lot of other people, it seems) and I'm getting a strange beep code when I boot. It's one long, two short, repeated continuously.
From what I can find on google that means a problem with the video adapter. The card I'm using is the XFX GeForce 7300GT 256MB PCI-E card. It gives me that beep code when all I have plugged in is the CPU, RAM, and vid card. But I also tried booting with an old Matrox PCI card that I know is good (cleared CMOS before booting) and I get the same beep sequence.
Then I tried booting with just the CPU installed, i.e. no RAM, and I get the same beep sequence. Also cleared CMOS before this boot test. Shouldn't I get a "Bad RAM" indicator in this case?
Not sure what else to try. Any suggestions?
Have another PCIe card you can borrow to play around with? See if you can get another one and update the bios...maybe that would help.
No, I only have the one PCIe card unfortunately. I was hoping to try that with my PCI card, because I pulled it out of another computer that was working fine. But it's wierd that I'm still getting the beep error even when I have a known-good PCI card in, isn't it? Makes it seem like the problem is something else to me. I'm going to try messing around with it again this evening.
Anyone have any other thoughts?
OK, problem solved. Turned out to be a dumb mistake as I was hoping. My RAM wasn't properly seated on the board. In this case the beep sequence didn't mean video error; it turns out that one long, two short means a memory error. When I seated the RAM properly everything worked fine.
Yeah, I guess a lot of AM2 owners learned that one long and two short beeps refers to the problem with the memory.
Wish Asus would provide the *complete* list of beep codes somewhere, instead of just the "common" ones...
FYI, I've also found that some PCIe motherboards won't show video or post without a PCIe card. PCI cards don't work. Last one I had that did that was a Chaintech VNF4 Ultra which was pseudo-popular among the budget enthusiasts.
