We've been trying to figure out what the best way to store DVD movies is long term. We have a bunch of DVDs right now with some in the safety deposit box, safes, and in a DVD case in our living room.
Recently, when trying to play one of the older DVDs, we noticed it wouldn't play on the Xbox. But when trying it on the computer, it worked (presumably because of better software?).
We also are trying storing the MOV/MPEG files on 64GB flash drives, but that is pretty expensive and there is some concern of bit rot.
What's the best way for video files to be stored long term, but for the home user? Basically, we can't use special tapes for archiving or whatever large companies use for long term storage. Should bit rot be a concern?
It'd probably be better to stay away from cloud storage, but if that is really the best way to store stuff longer term and offsite to prevent data corruption, then it'd be a consideration.
EDIT:
Note, these are home DVD movies, not ripped DVDs
EDIT:
