I have a question that I KNOW is a FAQ, but I can't find the thread with the answer.
I'm running 51C/122F at load on an Athlon XP 2000+ but my system is a little loud so I'm trying to drop the fan speeds as much as possible. The question is how hot can I let the cpu run without risking it? I run the computer 24 hrs a day so stability and long life is important. Normally it's about 112-117F but whenever the room temp gets above about 80F the case and cpu temps climb. Case temp is 96F with a room temp of 83F.
The case is a lian li pc-60 usb using the fans that came with it (2 intakes running at low speed, one exhaust) and a dual fan (exhaust direction) psu. The cpu heatsink is an SLK-800 with some sort of speed controllable 80mm fan, currently running at it's top speed.
Thanks in advance!
Thanks in advance!
