SteelSeries Rival FPS Optimized Optical Gaming Mouse - $40
Hell yes, been patiently waiting to try this mouse out, now I get the chance!
This is an exceptional deal. I picked mine up @ MSRP a month ago and don't regret it one bit. If you're a fan of the Deathadder and prefer a more contoured grip with an optical sensor give it a try, and yes you can change colors or turn them off all together.
The software works very well, as you're able to turn off angle snapping/acceleration.
I agree. I went from a Deathadder to the Rival when it first became available from Amazon and haven't looked back.
Perfect timing, my CM mouse died over the weekend so just ordered this as a replacement.
I bought one today at microcenter (they priced matched against frys) and its bigger and lighter than I expected.
Ahhh didnt see it was the same price at fry's. Just cancelled my order on amazon, will be dropping by fry's after work :D
Thanks OP! Picked one of these up at Best Buy on the way home - price matched to Amazon and had some reward zone points to redeem.
Seems like a pretty awesome mouse - very comfortable! The rubber coating on the sides has a really nice texture.
yup been using it for a few hrs now and I like it a lot.
i'm coming from a zowie fk, steelseries sensei, and a zowie am. I'm more of a claw grip type of user and the rubber really helps.
Nice looking mouse and good deal id say. That said, this roccat kone pure is fucking delightful.
Believe the hype. Between this mouse and the Deathadder 2013, I cannot feel a huge difference which is comforting because that means they pretty much confirm with each other how real mice should track!
I guess the next best thing for me would boil down to comfort and build quality. As far as comfort, I am not a picky guy for how mice rest in my hands, so I would rate them both the same. The scroll wheel is a big difference, I like the more stiff scrollwheel on the Deathadder, the rival is a bit loose, don't like that very much. That's pretty much what stands out for me between the two.
I was waiting to see if amazon would have em back in stock at $39.99 so i can price match and use $25 rewards.
Denied... Price on amazon went back up.
You can pricematch it at bestbuy with fry's (its on sale for 39.99 til the 15th I think). Thats what I did.
