Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I guess it depends on what you are doing...if you multitask, sure, the 3800+ will win. If you do game to game comparison the 4000+ will blow it outta the water and is about the same as the 4400+
You should let the water system run without the mobo powered (jumper the 20/24 pin connector - lots of sites show how) for a while to get all the air (those bubbles and "cloud" you are seeing) out. I haven't tried my new t-line setup yet (yes it's in a X-Qpack, but I don't have the radiator mounted yet, so no worklog/pics yet), but supposedly t-lines take longer to purge than a reservoir. My full-size system (with reservoir) was pretty much purged when I let it run overnight for a leak test...
