Steam Problem-won't load
VA Supremacy
So I can't get Steam to load or do anything.
I did change some cloud thing from Dallas to Houston but that's it.
After that I haven't been able to use Steam.
Is there something I can do?
I tried to uninstall but windows 7 said something about compatibility mode.
Anyone have idea of what to do?
IcarusSC
Check the Steam support site. It's full of really helpful how-to guides for troubleshooting: support.steampowered.com.
DeathPrincess
The compatability mode message doesn't mean anything. If you read it it says something like "cancel to ignore" of something I don't remember exactly, but just click somethign then it just ignores the messages and then you can continue.
VA Supremacy
I checked the steam site which is why I came here. I was confused at what to do and I hate leaving [H}:p
VA Supremacy
decided to keep it uninstalled I have problems with some games anyway on this computer (laptop) but not the HTPC where Portal is installed.
I'll try it again if I find something that really runs smoothly and exceeds system requirements.
