Steam Controller
What are you using the trackpads for? I look at the thing and I can't fathom a use.
If you’re using the controller on a TV setup, they are essential (assuming you don’t have a keyboard and mouse hooked up). Even games with proper controller support often have launchers that require a mouse to navigate.
Plus as others have said, you can remap them to anything you want via steam input
You can use either I'm pretty sure Wallet CC or PayPal. I been using my PayPal rewards on my Steam account to save for these totally out of control digital prices.
Had to check how my reservation is going and the estimated time of arrival is on december... And I put my reservation on the very next day the reservation queue was announced. Shit, how slow are they making these? It is after all just a controller. 😅
Mine says 2027 lol
On that note what would be the most compatible controller besides the steam controller?
These are good as it gets the Buttons are mapped A,B,X,Y instead of PS5 buttons which for some games they don't have PS5 buttons mapped. I'm pretty sure you can use Xbox 360 controllers from two decades ago so these should be good for along time. They have USB C connectors you can use almost any phone cable if it goes bad or use wireless if you want.
My dusty controllers usually use the top one less dust =) plus you can change out Analog sticks they are magnetic IMG_20260727_102014.jpg
You can use them for games that support a mouse cursor at the same time which can make things like inventory management and menu usage easier (highly game dependent). You can also set them up as custom hotkeys; e.g. assign them for direct access to weapon/items. There are other uses as well but these are as far down the rabbit hole that I've gone.
I was playing Civ V last night, much better experience than just using an Xbox controller (which is technically fine).
Interesting. Maybe I'll have to look at it in the future. That's my only issue right now with my TV setup right now is having a mouse on the end table next to the couch for launching games, YouTube, Netflix, etc.
If you have a ps4 or ps5 controller, you can get the exact same functionality so don’t really need the steam controller for that, but the extra 4 back buttons (plus the dedicated steam and quick access buttons) make it worth having IMO
I'm running xbox controllers right now. I have the old Steam controller from way back but could never get used to it.
AFAIK the 'advanced' features on the PS controllers don't work unless they're plugged in. Maybe the touchpad is different though, I haven't tried it wirelessly in a while.
You know - I've been using a Dual Sense for my SteamOS desktop build and had no idea you could use Steam's 'radial' functionality for the controller. Very cool, I'll have to check it out on my days off.
Yeah that's true, the DualSense controller's Adaptive Triggers and the haptic feedback rumble don't work on PC unless you are using a wired connection.
All you need for that is DS4Windows. Then you can use the touchpad on a DualShock 4 or DualSense controller to control the mouse cursor on your Windows desktop.
They make navigating Steam, web browsers/streaming apps, and many games, (especially older games), UI's far easier. While I still primarily aim with the right stick I often switch to the pad for finer control. I never thought I would use it either until I had it available. I will never buy a hand held that does not have at least one track pad. Preferably on the right side. It can be one of the tiny ones, but it has to have one, or I need an extra Steam controller to use with it.
I think that applies to the triggers on the ps5 controller but AFAIK the rest of the functionality works ootb wirelessly via steam
As I mentioned above, the Adaptive Triggers and the haptic feedback rumble are the only things that require a wired connection. Oh and I think DualSense speaker usage too.
Went to wallyworld and got the wireless one and everything works perfectly, thx again.
Still using my Steam Controller as my primary "general use" gamepad and overall quite happy with it. If anyone has questions let me know, in terms o gamepads I have practically "everything" first party (modded or otherwise).
MS Xbox Elite S2
NIntendo Switch Joycons + Pro Controller
Nintendo Switch JoyCons + Pro 2 Controller
Sony DualSense / DualSense Edge
Steam Controller
While I've not tried it myself as of yet, there is a family of (free and open source) utilities that allow you to use even all the advanced functionality over Bluetooth, because it basically tells the controller its connected via USB - https://github.com/awalol/DS5Dongle. Note that is the "basic" version, but I suggest looking down at the "community forks" for full featured options. These require a Raspberry Pi Pico 2W to create a a dongle capable of BT bridging with all features intact; some of the forks even support multiple controllers and configuration visibility on a commonly used OLED compatible with the Pi Pico2W etc. I've thought about building and flashing one just for the heck of it, but I'd need to do a bit more research on the varying forks and ensure that it works smoothly with DualSense Edge + Steam etc. Still a neat little project and having a dedicated BT dongle for my DualSense (Edge) would be nice.
MS Xbox Elite S2
Steam Controller
If you mainly use mouse and keyboard is the Steam controller good enough to make you switch over? Yes, very subjective question, sorry.
Have you tried using it with Xbox Game pass? Or Xbox box remote play?
Is it your favourite controller? Or is it too new yet to ask that question?
Thanks. Debating between the 8bitdo Ultimate 3E that is coming out soon and a Steam Controller. The former has the traditional xbox layout that I'm used to but is more expensive. The Steam controller has a different layout but is cheaper and has some extra functionality. I have time to decide.
It depends on the game. Some of the earlier Sony games require it to be wired, but other games like Helldivers 2 work fine wirelessly. It is hit or miss but I think the more recent games support it wirelessly.
Speaker is def a wired only thing, there is a github repo out there that lets you use a raspberry pi zero w to get more functionality wirelessly
I generally find myself with a "right tool for the job" approach, so it comes down to the particular game and/or game type. Some titles are more heavily leaning towards gamepad use in mind - like cross platform 3D character action titles (God of War, Assassin's Creed, Bayonetta, Devil May Cry, Wonderful 101 etc ) or 2D action platforming or metroidvania (Bloodstained Ritual of the Night, Bloodstained Curse of the Moon 1 and 2, NineSols, Hollow Knight, Mina the Hollower, Shovel Knight , Guacamelee STCE etc) and while they can be played with a keyboard and mouse, many may find it more cumbersome. Likewise, RTS and similar genres may be practically made for KB/M. The Steam Controller as with its predecessor a decade ago (and the Steam Deck's touchscreen and touchpads), is noteworthy for both its hardware and Steam's software bindings making it easier to play a game "not meant" for its type of gameplay. That's one of its strong points, as well as (unlike Steam Controller 1.0 which had only a single thumbstick and awkward button cluster location etc) being a damn good gamepad for games focused upon its usage.
I don't think I'd "convert" to play KB/M focused titles on gamepad or vice versa, but the Steam Controller makes it much easier and more capable to do just that if you so desire. Games I couldn't even picture how to handle on an Xbox Series X/S gamepad to any degree of proficiency I can think of playing on the Steam Controller / Steam Deck and have both customization and hardware to give rise to successful play thanks to its haptic touchpads and other features, but that doesn't mean that I'd necessarily prefer it over KB/M if everything was equal and available. Then again, as the Steam Deck has shown and Steam Controller continues, in cases where you may not have or it may be difficult to use a full on KB/M setup - like a living room couch - these alternatives make playing any game type easier and more accessible.
I can't say I've used it with either, as I've not favored those platforms. From what I read that it does work smoothly however . Closer to its launch it took either using Steam's overlay to have things "just work" or a different driver utility (depending on your OS), but I'd have to look to see what support if any Xbox has coded in native. Some emulators or launchers have support coded in since Valve released the specs to support the Steam Controller, but there are also 3rd party open source utilities.
I'm not sure about that yet given how long I played with others, but its definitely comfortable and useful for many games. I still use KB/M for certain games, and switch to my DualSense Edge for those that specifically make use of its features, but the Steam Controller is very capable of being a daily driver gamepad.
Got the email last Tuesday, ordered right away. Shipped Friday, somehow made a tour of the west-coast in the wrong direction before they sent it back to original shipping location and I got it yesterday.
Got home late so only briefly tried it with FH6. It feels a lot different than either xbox or PS5 controller. It does feel well made but will have to get used ti it. Do like the dongle.
I just cant see how these controllers are worth a hundred bucks. I missed my reservation due to life circumstances. But in a way im not bummed I missed it. There are a hundred different controllers on the market and after putting thought into it after the fact, yeah I dont see any problem with a lot of other controllers as being better in both price and layout than steam Controller and possibly performance. I have a steel series duo blutletooth and wireless and it just works amazing. But I am bummed because I could have sold the controller to another user here to help them out but I missed the boat for my order due to life distractions.
There are plenty of $100+ controllers, and I don't own any others. I have a few 8-BitDo controllers because they are an excellent controller and very well priced. I have original xbox and PS5 controllers. Depending on the game some controllers are better suited to some games than others. (like the long pull triggers for racing games) So I get it. But the Steam Controller does feel different with all the buttons and customization it can do. I have no issue with the $100 price tag. Once using it, I feel like it's justified. Everyone is welcome to their opinion if it's worth it or not, but just giving you my otherwise frugal view on it.
Thanks for the detailed reply. Turned down buying the controller when I had it on reservation. Will think about it and might queue again.
Finally reached the top of the waitlist today and got my email to buy the controller.
I've had it for a few months now and it's completely replaced my other controllers. I've hardly used the touchpads but the rumble on it is way better than the Xbox controller and it doesn't need to be plugged in like the PS controller. The sticks are smooth and the buttons are quiet. The battery lasts forever. Steam Input is also pretty amazing. It's 10/10 for me so far.
Had mine for a few months and I barely use it. Much prefer my DualSense. In the situations where I thought the Steam Controller would be useful, like closing dialogue boxes or pop ups or whatever when using my PC from the couch, it doesn't even work. Sometimes the input isn't set up until Steam is running, or like the specific game I'm on doesn't let me use the track pad so if another window has focus I can't interact with it. Overall pretty disappointed with it.
Checked the order status today--when I placed it a couple days ago they were saying estimated time to delivery was 6-10 business days. Today there's a UPS tracking number showing estimated delivery Friday morning.
Got my controller this morning. The box was fancy--clearly they took at least some inspiration from Apple--and it came in another box so nobody'd know it was a Steam controller (unless they looked at the "valve corporation" return addresss) which was also a bit fancier than normal, in that it opened slightly differently from most boxes.
First thought: it's big enough I immediately thought of that really old Penny Arcade cartoon about how big the original xbox controllers are. It's noticeably bigger (but not actually physically a LOT bigger). Second thought: the sticks fit under my thumbs like they were made for me personally, and they do a good job of naturally keeping my thumbs off the touch pads. The triggers are the same--the lower ones sit right under my fingers. The other four bottom buttons, not quite so much, but it looks like it'll be pretty easy to use.
