Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
What sound card / motherboard / power supply are you using? Are you running the audio cable by any noise sources such as a fluorescent light? How is the power in your area?
Do you get the sounds when the speakers are not plugged into the sound card? (don't touch the metal plugs with your fingers, this can cause noise on the signal line too.) If the noise remains then we know it's something with your speakers and not your computer/card
If the noise goes away, try the onboard audio. If the noise goes away, then we know it's the Creative card. If the noise remains then we did deeper into the realm of EMI/RFI.
Somewhat off topic, but I had a super cheap pair of speakers that picked up radio waves once. The length of the power cord plus the built in cord between the speakers was just perfect to faintly catch some crappy music when the atmospheric conditions were just right. To prevent this, I wound the cords tight and used a detachable monitor cable choke (magnet).
