Viper87227 said:Looks nice. How about a clear top?
Dillusion said:no clear tops. only black and white, its made of delrin.
BioPort said:to be honest, it doesnt look like a great waterblock.
of course, thats because he hasnt shown the portion that sits on the die. somehow i really doubt it will be very good. his patented "pinfin" design sounds too much like what coolermaster is using in their gpu blocks.
Dillusion said:That coolermaster block is nothing like his 'pinfin' design. those Cm blocks are just air coolers with plexi around them, they suck ass.
Street MSRP of these should be just under the DD blocks.
revenant said:yes, and fairly light also.(it's very similar to, or a type of Acetal, right? like what DD uses for it's maze gpu tops)
EDIT: here we go
"Acetal is the common name for a family of thermoplastics with the chemical name "PolyOxy-Methylene". Acetal is available in a general purpose copolymer grade, a homopolymer version (Delrin ®), and several filled Delrin ® grades. Acetal provides high strength and stiffness, enhanced dimensional stability, and is easy to machine. As a semi-crystalline material, acetal is characterized by a low coefficient of friction and good wear properties. "
http://www.boedeker.com/acetal_p.htm
Erasmus354 said:Dillusion : How about scoring us some pics of the actual core of the block, and the underside of the delrin. It looks to me like the water doesn't actually flow over the ram.
DocFaustus said:Ask him if they will be made for 1/2" fittings or will 1/2" line users be forced to adapt down to the 1/4" mentioned in other thread?
Pherret said:Something tells me they may not have buckled down a design yet for the gpu cooling portion. Im sure some major testing is being done.. and to release pictures of what may not be represented in the finished product (especially if it is not yet refined design) easily spreads some negativity that cannot be made back up when the product is in fact released.... even if the final product is a good design.
penguin said:The measurement in ppe threads measures the radius, not the diameter.
Therefore, 1/4" NPT = 1/2" hole, and is usually used for any range of barbs from 1/2" down, and even has barbs available for the small bore crowd.
NP. BSP fittings are like that as well, IIRC.DocFaustus said:Thanks for the clarification on NPT fittings.
penguin said:The measurement in pipe threads measures the radius, not the diameter.
