Starting slow, need a motherboard and processor
kenprescott21
Hey guys,
Awhile back I posted a build (by the help i got i realized I had poor hardware choices), you guys quickly suggested a better build. Although I cant afford everything I need all at once, I want to find the exact components I want and buy them when deals come about.
The pc will be used for gaming and photoshop work. Im looking for a good mobo, with a cheep processor that I can overclock, dual core preferred, eather brand. I dont need dual video cards, although if you guys could suggest one that is cheep and also overclockable that would be great.
With so much overclocking I would like to go with watercooling, or maybe air cooling if it works well enough. (Depending on the case I choose) What do you guys suggest? Ive been looking at the 300, with a 600+watt Corsair power supply. The case and the ps are about all I have confirmed, everything else im hurting on.
Thanks guys throw down lots of links and information for me, I want to read it all and drool on myself when I get out of work tonight. :)
Since you always get more for your money the longer you wait, I'd suggest waiting until you've saved enough before buying the core components. While saving, you may come across great deals for some of your non-core components, like the case, PSU, etc. When you see a good deal, jump on it. ;)
Danny's build from your last thread is still pretty good. However, depending on how long it takes you to save, there most likely will be a better build by the time you're ready to buy.
QFT.
So save your money, if you think you see a good deal (i.e the part is pretty close to the w/e part I recommended in performance/flexibility/features/etc, then jump on it.
Oh in case you're wondering what the core components are, at least what I think they are, here it is:
- CPU
- Motherboard
- RAM
- Video Card
Like enginurd said, wait until you've saved up enough money for the core components (more money you save, the better/faster core components you can get), then ask for recommendations.
Ok, Ill go ahead get a case, ps and keyboard and mouse.
What would be a solid, dependable and cheep (lol) power supply. How many watts for the system my boy Danny recommended?
Wattage is not the only consideration when choosing a PSU. You have to factor in the construction quality, whether or not it can actually provide the rated power, how much amperage there is on the +12V rail, efficiency, and a bunch of other factors. So keep that in mind when choosing a PSU. In other words, not all PSUs are made equal, even if they share the exact same wattage and even manufacturer. So with that said, I recommend the same $65 Antec EA650 650W PSU recommended in your other thread. It's relatively cheap, solid and a great quality PSU. Granted the system that I originally specced out for you will NOT need 650W of power (Probably a quality 500W PSU at the most) BUT at $65, the EA650 is priced lower than many excellent quality 500 to 600W PSUs but offers close to the same performance.
I totally agree with the Earthwatts 650 recommendation and pretty much everything else said above. I too last month completed a super cheap near $500 budget gaming rig. I went with the EA650, as well as a combo deal on a Gigabyte mobo and E7200. A 2x2gb ddr2 kit which was $39 AR. So yes its absolutely possible to make a semi-decent rig for cheap.
