start up win 7
automaton
Yes HKCU:Run AdobeBridge
Yes HKCU:Run swg Google Inc. "C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe"
Yes HKLM:Run Adobe ARM Adobe Systems Incorporated "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
Yes HKLM:Run AdobeAAMUpdater-1.0 Adobe Systems Incorporated "C:\Program Files\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.exe"
Yes HKLM:Run AdobeCS5ServiceManager Adobe Systems Incorporated "C:\Program Files\Common Files\Adobe\CS5ServiceManager\CS5ServiceManager.exe" -launchedbylogin
Yes HKLM:Run AVG_UI AVG Technologies CZ, s.r.o. "C:\Program Files\AVG\AVG2013\avgui.exe" /TRAYONLY
Yes HKLM:Run RtHDVCpl Realtek Semiconductor C:\Program Files\Realtek\Audio\HDA\RtHDVCpl.exe -s
Yes HKLM:Run StartCCC Advanced Micro Devices, Inc. "C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" MSRun
Yes HKLM:Run SunJavaUpdateSched Sun Microsystems, Inc. "C:\Program Files\Common Files\Java\Java Update\jusched.exe"
Yes HKLM:Run SwitchBoard Adobe Systems Incorporated C:\Program Files\Common Files\Adobe\SwitchBoard\SwitchBoard.exe
Yes HKLM:Run vProt AVG Technologies "C:\Program Files\AVG SafeGuard toolbar\vprot.exe"
Yes Startup User Samsung SSD Magician.lnk Samsung Electronics. C:\Program Files\Samsung SSD Magician\Samsung SSD Magician.exe
Any obvious things I can disable?
You can disable Samsung SSD Magician.lnk Samsung Electronics. C:\Program Files\Samsung SSD Magician\Samsung SSD Magician.exe
and google toolbar one
SunJavaUpdateSched - update scheduler for Java is one I normally delete.
GoogleToolbarNotifier - checks that google is your default search engine. delete/disable
-- but, it will come back by just going into msconfig
Found this - may help you.
http://www.online-tech-tips.com/google-softwaretips/what-is-google-toolbar-notifier/
AdobeARM - Adobe updater - same to delete/remove
-- http://forums.adobe.com/thread/522601
RtHDVCpl - Realtek Audio control panel. I've always used Windows audio control and deleted this entry.
Hope this helps some!
