daphatgrant
Fi-yah!
- Jun 15, 2003
*Update - Resovled
I messed with it some more and I am able to place a shortcut or a folder with a shortcut on the Start Menu in any of these folders individually and it will appear. Folders have to be created in those folders though, creating a folder elsewhere even with a shortcut in it and dragging and dropping or cutting and pasting to these locations will not have that folder appear on the Start Menu, little caveat I guess.
C:\ProgramData\Microsoft\Windows\Start Menu
C:\Users\User\AppData\Roaming\Microsoft\Windows\Start Menu
C:\Users\User\ApbpData\Roaming\Microsoft\Windows\Start Menu\Programs
Nothing I put here will show
C:\ProgramData\Microsoft\Windows\Start Menu\Programs
That's all I guess, make sure that you are;
1. Using a shortcut, only shortcuts will show
2. If creating a folder, add a new folder to one of the top 3 addresses, dragging and dropping or cutting and pasting from another location will not work, it has to be a newly created folder within one of those locations. You can however drag and drop or cut and paste shortcuts into the folder after it's been created.
Original Thread:
Hello all, I'd like to add a folder to the start menu but I can't seem to accomplish that. I've done some googling after trying what I thought would have been the way but have not had any luck. I'm using Windows 10 Pro, 1809 Build
Here's my start menu;
I just want to add a folder like the "Bob" folder I PaintShopped in.
Anyone know how to do this? Or if this is even possible anymore?
I tried adding the folder to;
C:\Users\User\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
and even here.
C:\Users\Default\AppData\Roaming\Microsoft\Windows\Start Menu
C:\Users\Default\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
I've tried restarting and haven't gotten anywhere.
Thanks for any info
Original Thread:
and even here.
Thanks for any info
