Leon_Solitario
- Dec 23, 2009
Q6700
Nvidia 680i SLI
Corsair 2x2 DDR2 800
Sapphire HD 5770
current voltage setting:
vcore 1.36v
fsb 1.5v
memory 1.8v
spp 1.55v
mcp 1.5v (can't drop any further)
ht 1.2v
current clocks:
multiplier 10x (max)
fsb 1333MHz
memory 800MHz
pci-e x16 100MHz (not sure what to do here, can't seem to find much info at all)
ram 5-5-5-18 2T (tRRD 3, tRC 23, tWR 5, tWTR 9, tREF 7.8uS)
gpu currently OCed with MSI Afterburner (max settings doesn't hit over 61C)
I'm currently in the process of trying to stabilize an OC on my rig. so far I've brought the CPU up to 3.33GHz@1.36v. I'm still raising the voltage on the CPU to see if I can get it to pass stress testing without dropping the clock speed (3.33GHz@1333fsb), but if that doesn't work I've read that slowing the timings of the RAM can help to increase stability. the problem is I don't know where to start and the guides I've read are vague on the matter, so any suggestions would be greatly appreciated.
currently it seems to fail (reboot) after ~45min of Prime95 blend test stress testing. temperatures haven't exceeded 58C.
Nvidia 680i SLI
Sapphire HD 5770
vcore 1.36v
fsb 1.5v
memory 1.8v
spp 1.55v
ht 1.2v
current clocks:
fsb 1333MHz
memory 800MHz
