My bad.Bbq said:The 'F is a modular with a 120mm.
The 'ZF is not modular, with an 80mm.
Jerry said:It's a little larger than your standard PSU btw, so it might be a tight fit.
Jerry said:Yes, it's a little bit longer than your standard PSU.
Which one would be more quite?dBTelos said:One of those should be able to handle your rig...
Tanquen said:Which one would be more quite?
dBTelos said:They're the same supply, so the same quietness. I was talking about your ST60Fs.
Tanquen said:I just ordered both today to see which I like best as one of the ST60F supplies I have is too loud.
J Macker said:so replace the fan in it. Not hard to open a psu and replace the fan. That's a lot of money wasted, imo.
you're in luck the silverstone modular psu is the only 1 that has a short cable kit available for it (aside from custom cables from pcp&p)
you can buy the kit here
http://deadeyedata.com/index.php?ma..._id=16&zenid=840ca06a994a9dc0f1952644e1216996
