its a piece of cake. on my amd board, i had to uninstall the nvidia storage drivers to get the intel software to recognize the drive. that was my only snag.
hmmm, what board you using?
Except trim isn't supported in raid, and if you're running an AMD southbridge, raid is a complete joke.
I had no problems at all with the firmware update. Trim enabled!
which method did you use 1,2, or 3?
well, all 3 are the same really, but I went with 3 because it was recommended and it was the easiest.
Did you try /d=10 as suggested in the thread? Another option is Linux and hdparm, there's directions for that too.[H]'er;1035541545 said:HDAT2 caused me problems, but were fixed by not plugging in the SATA cable until DOS was loaded...crazy, but worked. Otherwise it would not load the program.
7.6 non-RAID, I don't know what RAID 0 would do but it only goes up to 7.9. WEI is kind of pointless anyway...so just curious here... what's the windows 7 score with a single kingston drive and score of them in raid 0
Assuming you're talking about the flashing part, I went with 1 because USB drives are rewritablewell, all 3 are the same really, but I went with 3 because it was recommended and it was the easiest.
