Hi, i am confused after reading controversial opinions about some SSD "tweaks". Most notably, Superfetch. I have googled and found passionate opinions about that and i wonder if by now the things have settled to a more "common opinion".
Win7 is "supposed" to disable Superfetch and disk defragmenting. In my PC, the WEI gives 7.9 score to my humble Kingston VP200 120GB SATA3. Windows though didn't disable disk defragmenting (i disabled it manually) and has set Superfetch to "manual". Unfortunately, this is probably causing repeating event viewer errors about Readyboot:
The maximum file size for session "ReadyBoot" has been reached. As a result, events might be lost (not logged) to file "C:\Windows\Prefetch\ReadyBoot\ReadyBoot.etl". The maximum files size is currently set to 20971520 bytes.
Session "ReadyBoot" stopped due to the following error: 0xC0000188
So, i am wondering whether the guys saying Superfetch should be on, were right after all.
What is the consensus nowdays?
Thank you.
Thank you.
