So I am about to build a new PC and I have decided to go SSD route. I am building an i7/Crosssfire setup. My i7 will be the 920 and the Crossfire will be a pair of 4950's. I will be buying 2 OCZ Vertex 60gb drives with RAID 0 in mind.
Questions:
1. I hear that buying a RAID card will give me the best performance. What card would you recommend? Like to spend <$300.00
2. I was thinking about getting this MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813188039. Can I run my 2 4950's at x16 and also run my RAID card at x4 or x8?
3. Also what is the difference between these 2 boards:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188046
4. And last, if you think their is a better i7 MOBO, please recommend it.
Thanks!
Questions:
Thanks!
