ssd question
manny1222
Is there any advantage to having OS and games on 2 separate SSDs, I'm.considering getting a larger ssd for games. Should I just have them both on the same drive?
I don't think there would be any perceptible performance difference with 1 SSD vs. 2 separate SSDs. The advantage with 2 separate SSDs is you can potentially prolong the usable time for each drive (before a re-wipe) by not having 1 single drive mostly filled all the time, which could take a hit on SSD performance and lifetime because of how disk use and garbage allocation generally work (though firmware continues to get better and better for these things).
That's not really a concern with modern SSDs, by the time you've written enough data to notice a decrease in performance (many years) your SSD will be ancient and newer, faster and cheaper models will be on the market.
OP, your OCZ Agility 3 isn't exactly a great drive so if I were you I'd look out for some deals on a 256GB Crucial m4 or Samsung 830 and putting everything on there.
Yeah, that's a good point--most current/modern drives are good, and this shouldn't be an issue in general.
gererally larger the SSD the faster it is but if you have 2 drive it will allow you to be more versatile
2 x Corsair 3 240G in raid 0, i had an avg of 1G though put on it and just tossed my 200G steam folder on it, LOVE the speed!
